I wonder if anyone can shed some light on a 'potential' problem that I have.
Recently had new central heating installed and had lots of problems with the plumber, but that's a side point. I wanted to check whether I have a problem with the new boiler, or whether it has been installed incorrectly.
I have a 3 story house, and each floor has its own independent thermostat. Each of these feed back to a non return valve (not sure of the correct name) which opens when the relevant thermostat calls for heat. The idea being that the whole house doesn't get heated needlessly and each area is zoned.
Now, the problem is that the guy forgot to do this at the start, and I have to point out he'd done it wrong. He then messed around with a few pipes and eventually put them in place. The problem, is that now I have a towel rail in a cloakroom which is before either of the three valves on the flow pipes. What this meant in the winter was irrespective of what zone was on, the towel rail heated. At the time, this didn't bother me as it was nice to have it warm
Anyway, with the warm weather we have been having, obviously the heat has been off, however the towel rail is constantly hot !
I have the temperature of the boiler set at approx 50 degrees and what appears to be happening is that the boiler is constantly keeping the water heated to that temp even though the valves are shut and it's not flowing to the rads.
Each of the thermostats has a wire going to the valve, which in turn has a wire going to a junction box. So I have a junction box with three wires going to it (the 3 valves) and one single wire going to the boiler controlling the on/off i guess.
Question is, is it a boiler fault that means the water is always hot (not very energy efficient) or is it a problem with the wiring from the junction box to the boiler in that it is telling the boiler to constantly heat the water?
As an aside, my gas bill have become HUGE so ideally wound this fixed asap. It doesn't effect the heating working, just things don't seem correct to me.
I have a picture that tries and illustrate what I have described above., however I'm not sure how to upload it.
Any thoughts would be greatly appreciated.
Many Thanks
Many Thanks
