worcester bosch gas boiler water temperature.
2 Dec 2007
Yorkshire
Can the water temperature on a worcester bosch greenstar 28i combi gas boiler be altered. had ours since december 2007 and hot water never seems to be very hot. I understand it is limited to 55 degs C is this correct and can it be upped a bit?
it probably doesnt have a thermostat control.
the fixed rate ones are usually just that.
Yes, you are correct yorksvilla. Worcester Bosch Greenstar have HW factory set to 55c. Should be flippin hot though I wouldnt stick my hand in without adding cold.
What happens if you turn the flow down....perhaps you are expecting too much out of your combi.
