Hi
A few questions . . . !
Recently moved in to a house that has a recently installed W/B Greenstar 8000 Style 35kw SYSTEM boiler. It is run from an old (non smart) Honeywell timer. A very large Ariston tank is fitted.
What is the optimum temp setting to have on the boiler? (can find lots about Combi boilers - but not system).
Only the heating light goes on on the boiler (not the hot water - there is a dial control at the base of the h/w tank to control the temp on that) - is that a normal setup?
There are 20 rads in the house, each has a Tado on and I have set each to specifics for each room (Tado brought with me from previous house) Its a big, cold old house, solid walls etc so its as thermally efficient as an old garden shed!
What smart control would be wise to fit so I have more control? - I gather that Tado all not work with the boiler. So Nest / Hive / Bosch own system ?
Any thoughts / help welcome!
Thanks!
Roger
Thanks!
Roger
