Worcester Bosch MT10RF Thermostat Faulty?
26 Oct 2009
Lanarkshire
I have a Worcester Bosch MT10RF Thermostat which has the day and night settings. I have just moved into a this house and thought it was pretty easy to operate until the heating came on and went off at times that we had not set!
What I have noticed is that the time setting outer ring shows a different time than the clock on the inner ring. Should these be the same? Which one should i use?
I am using the outer ring time just now but sometimes the heating doesn't some on when i want it and we end up sweating during the night even though the 'Night' thermostat is set to the min 5 degrees.
Also, the 'middle' setting which has a clock sign - is this a 'Constantly-On' setting?
Can someone please help as the manual I found online isn't the most helpful!
Thanks,
Brian
Long story short, its knackered. I've had several MT10's gone the way of the pear. Only this week I changed one due to it being on constant even though the clock was in the off position.
Its the cheapest clock they do so you wont get stung.
Worcester, not all they are cracked up to be :rolleyes:
