worcester cdi28 problem
1 Jun 2008
Bristol
hi i have a worcester cdi28 problem is .when heating is on full the fan keeps running and the pilot light keeps going out, then trys to relight theres also a clicking noise, it will do this for a while then run fine..
also noticed when running hot taps i need to turn them off slittly to reduce pressure as they are not hot when open fully not sure if both problems are connected anyone no what the problem could be
You need a gas engr for that one
That's normal - should be bath-hot at about 12 litres per minute.
with the taps they used to work fine on full but over time they have got worse..as for the other problem are you saying that it could be the gas valve i would not attempt that job but was just trying to figure whats up with it so i can price it up cheers :D
