Hi All, I recently went to service the above boiler. When i removed the combustion chamber cover the boiler was a bit sooty as it hadn't been serviced for a while. The baffles inside the boiler however are incorrect. There are supposed to be six but there are only four and they are larger than normal. It looks like they may have been replaced but are for a different model. I did all the necessary tests and all was ok i.e pump pressure, Co2 etc.. What would be the reason for fitting different baffles and what would be the effects on the appliance? Thanks
