Worcester digital timer
24 Jun 2012
Fife
Can anyone help?
I have a Worcester 240 rsf combi. The 'select' button on the digital timer does not work - it doesn't move through the options. Is this simply a problem with the timer and I need to replace it, or could it be something else?
I'm only asking as I don't want to spend £100+ on the timer if it could be a problem with another part.
Thanks in advance.
Press the day, hour and minute buttons at the same time to reset the timer. If its still the same then you'll be forking out some cash :D
If the timer is shot then you might be better off, from both a cost and performance issue, fitting an external 3rd party timer/programmer rather than replacing the built in timer with another one.
Those with greater familiarity with the options available might be able to recommend specifics.
Mathew
Thanks for the replies. It is goosed, I've tried resetting it. I never thought about an external timer, I'll look in to this.
Thanks.
