worcester greenline 42cdi
8 Jan 2010
Staffordshire
ok, just moved into an new house, and the above boiler is fitted, had a problem this morning with the pipe being frozen, and managed to get it sorted this afternoon. Thought everything was ok, but have had no heating since, and now the boiler has the same error code EA. The pipe that was previously frozen, i have cut short to stop freezing, but when i reset the boiler, i dont get any water release down it.
can anyone help?
I had the same problem - woke up yesterday - no hot water, reset and blue light flashing and error code EA
After a cold night had a look on the net today and fixed it - condensation pipe was frozen - flexible plastic pipe coming out the bottom
WB website very helpful
http://www.worcester-bosch.co.uk/ho...ting-questions/common-winter-boiler-enquiries
If this doesn't work for you then maybe work your way through this
http://www.worcester-bosch.co.uk/cache/file/1/greenstar-cdi-service-booklet-for-engineers.pdf
Let us know how it goes
sounds like your condensate pipe is still frozen to me try pouring a kettle full of hot water over it lump of ice will prob come out followed by water and gurgling from the flue this tells you it is clear
hit the re set button and away you go
EA is just no flame detected
yes, there was ice in the pipe, it was it the bit that went through the wall, managed to get the ice out, and cut the pipe off to give it less chance of happening. But still had no heating for some reason, in the end we ttok the front off and cleaned the condensate trap, and my dad blasted some hot air over the boiler, that seemed to work.
