Hi, I have just bought a property with a Worcester Greenstar 24i installed.
I drained the system down and refilled it just to give it a flush out.
The hot water system seems to work fine but...
When I try the C/H the boiler fires up but clicks off after about 10-15 seconds.
The pump sounds like it is working but sounds like air is trapped in it, could this be a cause.
The auto air bleed appeared to work but I think there may be an air lock.
The pump gets hot but the C/H water outlet pipe is still cold.
Is there a way to bleed the boiler manually & could air in the pump be the cause of the problem?
Any help will be appreciated.
Thanks,
Andy
Thanks,
Andy
