I recently changed a radiator in my bungalow. Followed what I believe was the correct procedure
Obviously this is something that's resulted from the work I've done. Have I made a beginners mistake?? Any help would be appreciated.
- switched off the boiler
- opening and draining from the drain valve
- opening all valves including the bleeds
- replace the radiator
- close the drain valve and bleeds
- turned boiler back on
- repressurise and bleed for each rad
