- Joined
- 29 Dec 2021
- Messages
- 5
- Reaction score
- 0
- Country
Good evening,
Apologies in advance, I am new to the forum but been reading a lot of threads helping in the past months.
I bought an house with a Worcester Greenstar 24Ri, working fine until last week I, started having issue with my diverter valve.
Short story, I came. back from home and after a few hors notice the radiators on (unsure if the hot water was from the rads on in the morning due to diverter causing issues or the boiler turning on on his own?).
Anyway, I opted to switch the boiler off as leaving for a few days from the thermostat Drayton (forgot the switch of the boiler itself).
Came back after a few days, turn it on (I hear it from the other room turning on) and then put the how water on. Nothing comes, thermostat looks on, go to check the boiler, no power, no green and blue light.
Figure out something was blown, one of the fuses on the PCB was gone (why? I don't know). Replace it, power back on and the problem starts.
When the boiler gets turned on I don't hear the previous sound, it is silent, so I tried to put hot water or radiators to check, I hear a quick click then nothing and flashing blue light start flashing quickly. I can see the fan is not moving.
My question is: do you think is the fan gone? Or is another component that should start before the fan, giving it the way to go? Not an expert.
I can also hear the the pump (located in another floor of the house close the the hot water tank) is not working. Also about this I am not sure if that should go on after the boiler start ignition or could be the reason why the fan not starting?
I am just trying to figure out if this is something relatively easy before getting an engineer cause me and my partner wanted to change the boiler anyway, but when doing an extension so I was trying to keep it alive just another year before changing the all thing.
Boiler was serviced by the previous just little less then 12 months ago.
Thanks in advance for any help.
