- Joined
- 5 Nov 2024
- Messages
- 5,864
- Reaction score
- 2,780
- Country
Could be the diverter/stepper motor, blocked plate heat exchanger, et al.
Pity you didn't answer the question above ,might have been able to save you buying a new shower.Does the shower go cold when only using the fixed head ,or same issue with hand held one ? If you remove the fixed head ,and just have open ended pipe ,does water still go cold ?
Inconclusive really. If you only use the shower hose with it's shower head attached, ( and I assume no water flows out the fixed head in that setting) does water run cold whilst showering in that mode ?Had a shower. I estimate it went cold after about 8-10 minutes. Jumped out and left it running. It restarted by itself after about 3 minutes at which point I switched it over to to the shower hose end with head not attached. Left it running 10-15 minutes and boiler stayed running with hot water.
