Morning all
silly question time I'm afraid.
had this boiler almost a year now. Works well (when the EEV doesn't explode...) but slightly confused with it. And the instruction manual is a little lacking.
There's no Hot water temp control. Does it rely on the Central heating temp control? With condensing boilers I believe you're supposed to keep the return water temp low, but lowering the out flow seems to lower the water temp. So you need to keep that high, which means the condenser doesn't work as effectively as it could
Also - if HW and CH are running at the same time, does one take priority (like the HW used to take priority on our old Worcester Combi) or is the output split evenly between the two?
Not really the most important questions (or answers!) in the world, but would be nice to know.
ta
madge
ta
madge
