Hello
I have noticed water droplets from the pressure relief pipe recently which has also changed colour at the end ( blue ).
I have kept an eye on the water pressure which on heating is always in the red / 3 bar. It then drops to 2 bar when water temp around 50 during the day / when no call for heat.
After reading the FAQ's I turned off the boiler, vented the rads ( which had lots of air in ) which dropped the pressure to zero and then checked the expansion vessel. the reading I get is 35 psi which is 2.4 bar. The FAQ's and the Worcester manual mention 0.75 bar. I then filled the system to 1 bar and run on max. The pressure now goes to to 2.5 bar when 80 degree temp.
- Is the 2.5 bar expansion vessel reading someone to be concerned with ??
- I take it the PRP droplets was due to the high pressure ?
Any comments will be very gratefully received. Thanks in advance.
