Worcester Greenstar Highflow 440 - add a Hive.
2 Jun 2021
Hi guys Im new here and just wanted to knw how to fit a hive system to my worecester boiler . I have the built in programmer on the boiler which will need to be taken out and a twin channel hive sysem installed so i can still boost the hot water . Has anyone done this and help would be great ie wiring diagram or video . Cheers
Page 49
file:///C:/Users/user/Downloads/Greenstar_440_and_550_CDi_Highflow_Combi_Installation_and_Servicing_Instructions.pdf
if using the hive you dont need LS for the room statas the hive has this inbuilt, if your boiler has a DT10 or DT 20 you will have to disconnect the ribbon between that and the pcb, be carefull not to connect the hive to the volt free thermostat connections , only use the 240v connections
I've sent it back to Amazon as I think it will be more hassle than it's worth. Cheers
just order the single channel hive very easy to install and will give you all the control of the heating via your phone etc, the HW is set at the boiler anyway and, the single channel hive is simply wired in as a room thermostat
Guys all fitted a all working great and hot water does work with this boiler. I used dual channel hive. Took a little bit of getting my head around the wiring.
