The most common fault encountered on oil combis ( and system boilers) is probably a failed expansion vessel. The internal vessel is rarely above 12 litres which is nowhere near big enough for the systems they are often fitted to when a 25 kilowatt boiler will often be serving a 4 bed detached house.
The fact they are right by the boiler also does not help as it has to contend with the ambient heat it is placed in so the casing is heated from the outside as well as by the water.
Dunno. The welds on mine look like they're done by machine. You'd need air in there to absorb the expansion of whatever was in there because water is incompressible.
