Hi all
I have a Greenstar Heatslave II oil boiler circa 2015.
The AAV and PRV both needed replacing which I have just done myself. I thought I did everything by the book, but now the boiler is stuck in lockout and won't even try to fire the burner.
Here's what I did exactly:
1. Closed CH flow and return valves
2. Let system cool completely
3. Opened main drain point and drained water in boiler until pressure read 0
4. Took off expansion vessel to empty it, then reattached and recharged air side to 1 bar
5. Removed and replaced AAV
6. Removed and replaced PRV
7. Opened main flow air valve
8. Opened filling loop until air valve passed water, then closed air valve
9. Closed filling loop once pressure reached 1 bar
10. Bled heat exchanger air screws
11. Bled nearest radiator (no air in it really)
So now the system is filled up and at pressure again, but when I try to switch it on I get the 955 lockout error.
The water pump starts to run briefly, but about 30 seconds later I get the error.
The burner doesn't fire. I can see its LED lights up red and flashes orange a few times, but that's all. Pressing the burner reset button does nothing.
I did not touch any oil or burner related things - only the water side.
I thought I had done everything right and took great care to do everything so I'm very upset that it's not working.
Any advice would be appreciated.
Bob
Bob
