worcester r30 He Combi - no fault codes but no heat: help..!
3 May 2011
Yorkshire
Hello -
I'm new to these forum so please excuse any naffness. Be great if anyone can give me some pointers/advice/etc. Just noticed tonight that the central heating/radiators don't work. The boiler - worcester bosh combi HE R30 Greenstar jobby - has no fault codes and it still produces hot running water. However, when the central heating is supposed to come on the thing fires up only for a few seconds and then goes quiet: radiators are stone cold. Like i said, no fault codes or anything exhibited. So far tried bleeding the radiators and switching the unit on and off a couple of times but no joy at all. thanks in advance. Mojo.
update - i've just run it using the 'chimney sweep mode' and it fired up nice and all the rads got hot... but that only lasts for 15 minutes and it's gone back to not working when set up normally.
Hello -
I'm having exactly the same problem; did you find a solution to this?
you have an external controls or internal timer fault, the chimney sweep mode is an engineers way of over riding these external controls and as such rules out a boiler fault the boiler shutting down after 15 mins is normal in this mode, what controls do you have for the boiler and I might be able to advise more
