when running a bath the water is only getting warm, used to be pretty hot any one help i turned the pressure up to nearly 2 bar done no good . radiators all heat up well though
thanks for reply ive noticed the temp dial was on low so hopefully that might of been cause if not try what you suggested.but i had new diverter valve fitted last year
If your diagphram is faulty it usuall leads to int hot water or none on the 9.24 its usually the complete valve ,run a bath when the heatings been off and if you can feel the flow and returns to the heating starting to heat up then its the diverter valve, when 9.24 block up and give poor hot water the boiler can generaly be heard overheating (kettling).If you do get a diverter make sure you get the corect one as two types available
