Worcs Bosch 280 timer propblem
16 Jan 2008
Hampshire
1) Boiler make / model (gas or oil)
Worcs Bosch 280 combi gas
2) What is / is not happening.
Cant set the boiler to come on/off using the digital timer. It only seems to work by turning thermo up till it (clicks) on, and off same way. Boiler is in outside cupboard too
3) Has ANYTHING else been done or changed recently.
Just moved into property so unsure
6) Anything else you feel may be of relevance.
The boiler was on frost setting, not sure if this is relevant.
Summary, there is a digital timer available which i have tried setting, but it doesnt turn boiler on or off. Only way to turn the heating on and off (which is then constant) is by using the thermostat.
As youi are not sure of the history get someone in to service it and, probably, replace the timer.
