Hi, i've got a problem with a Grenstar 30HE combi that i would like some opinions on. Basically what happens is when a hot tap is turned on the boiler fires normally and works perfectly well untill a cold tap is turned on while the hot tap is still running. As soon as a cold tap is turned on the flow switch lowers itself back onto the microswitch and the burner shuts off. The water pressure seems fine throughout the house and the pressure still seems ok even with more than one tap is running. I suspect it's probably just a duff flow switch which seems to be a large spring on this model but I wondered what the superior minds thought on here?
