Wondered if someone can help!
I have a central heating system with a header tank which I recently drained, applied cleanser and refilled. The radiators have been bled and the system works fine - problem - boiler is knocking, banging spitting! I have re-bled the radiators but no further air is coming out.
What may be the cause of the banging? Is there rubbish that may have found it's way into the heat exchanger when the header refilled the system? Is it some air in the boiler that won't shift? Apart from this, the system appears to work fine.
Further info - the temp difference between the boiler in and out pipe is 3 degrees C
Cheers and thanks
Cheers and thanks
