Wossat?
So which joker edited that to claim it's 2.5mm² with no evidence?
Someone round here, I suspect! ... File history doesn'tnshow any changes though….. (click here)
That seems to be the history of just the image, which may well not include the caption. The history of the whole article can be found here .. and seems to indicate that some change has been effected today.
Kind Regards, John
I did, although it was just an rough estimate.
If anyone can tell the true size of the copper cores then good luck, does not look like 16mm to me though.
which although is not identical, is 5 core 16mm, an outer diameter of 21.3mm.
I would of thought 5 x 16mm cores would have a larger outside diameter than 21.3mm. Place two 16mm cores next to each other and you would have at least 32mm right?
Wikipedia is not for rough estimates.
Diameter != CSA. A 16mm² solid conductor is only 4.5mm in diameter. Compare the visible diameter of the conductors with the total diameter of what appears to be 3G1 flex on top of the drum.
I should have left the core conductor size out. I have now removed it from the caption as we don't know what it is for sure [citation of conductor size].
True, don't know why i though the diameter would equal the area? My brain must have been turned off! :oops:
Area = Pi x radius squared; 3.141592 x (2.25 x 2.25) = 15.9mm²
