I think a tenant in a bungalow I look after is using a large radiator to dry her clothes on, the others are turned off. A room stat. at max is in a hall some way from the large rad.. As a result the boiler stat. is the one doing all the controlling and is switching quite often because of the high temperature.
Q. Is there a way of managing a c/h system such as this?
Q. I want balance the system so what would be the differencial temp. to
use when the room temp. is already 25c.
Q. I want to flush the pipe system. Its a condenser boiler, micro bore and trvs. Would I have any success by individually taking off each pipe to valve and pushing water through it by turning on the fill valve at the boiler ?
Many thanks for your replies.
