Our heating thermostat is positioned where we suspect it is being confused by the tumble dryer. The thermos is in a small hallway but around the corner in the utility room is the tumble dryer. Current thermostat is a Honeywell, boiler is oil fired Trianco Eurostar, (in the same room as the dryer).
We want to fit a ' remote' thermostat somewhere else and have come across these;
Honeywell CMT921 (ScrewFix)
Horstmann HRFS1 (5 star rated on ScrewFix)
As we are in rented property I don't want to start fiddling with any wiring unless it's to simply swap a unit. Will either of the above units be suitable, and if so, which would you recommend?
