I have received a Wrox for Christmas's. Trying to find on the Web sites for spare blades.
Customer service only sells the item , not the parts (bit of a joke that one)
Has anyone else had this problem?
Thank you
Presumably you are referring to a Worx WX426, since there is no Wrox or WE426.
The solution to blades is to look for those of the correct size, which for the WX426 is 85mm diameter with a 15mm bore. A size which is available from many manufacturers - it doesn't have to say Worx on it.
