Circular saw blades "for cordless saws"
2 Dec 2013
I have a mains circular saw. I currently have only coarse blades. I am looking to get a fine-cut blade for it.
Some of the Screwfix listings describe the blades as "made for cordless handheld saws". I presume this means that they are relatively thin.
Does anyone know if a "made for cordless" blade can be (safely?) used in a mains saw?
Example: https://www.screwfix.com/p/trend-wood-chipboard-mdf-circular-saw-blade-190mm-x-30mm-60t/341af
"Suitable for use with cordless circular, plunge and table saws."
Or, can anyone suggest a fine-cut blade, 190mm diameter with 30mm bore that I can use with my mains Makita saw?
Thanks.
Trend do a good range of thin blades for cordless saws.
just be aware
the clamp may not clamp tight to the blade iff its too thin ??
as in blade thickness say 1mm but clamp needs 1.5mm to grip
also the riving knife is blade specific so iff the slot is 1.7 and the knife is 3,2mm it will bind
@blup, I'm not looking for a blade for a cordless saw, thanks.
I bought a couple of the Saxton blades as suggested by ETAF. They seem pretty good though I've not done much with them so far.
