This is an unusual fault and its for a friend which makes it more important that I get it fixed soon but I dont have much time to spend and she talks a lot which means that it takes longer to get it done. I have only had a quick look and not fully checked the wiring but it seems to be correct.
Its a basic "Y" plan with programmer downstairs, motor valve and receiver for wireless stat in bathroom, Worcester Ri boiler on landing and cylinder in loft. Motor valve is quite new and seems to work correctly and switches are operated and click in the right positions as expected.
She is adament this is a recent fault and nothing has been touched. I have seen the fault occur that the boiler stays on when the timeclock is off for CH and HW.
Disconnecting the orange from the motor valve for a second removes the demand ! It seems that the call for heat is somehow causing something to "lock on" but once this is removed everything goes off as it should be.
If what she says is correct then something has changed/failed.
