y-plan
17 Dec 2007
Nottinghamshire
I've not done that many y-plans, so here's a pic of one i'm doing this week.
How am I doing....does it look ok?
GALLERY]
Put the 3 port the right way up!
When it leaks, it will blow the electrics.
Cant you 'pull' a set? (Pump to m/vlv) Cold feed in 15mm aswell.
Looks ok for an apprentice.
Fair point about the 3 port. I guess if it leaks the motor will be nice and wet. It was a bit tight for space, but I guess I could have flipped it on it's side.
nogoodatfaultfinding, Can you pull a bend to fit the valve in the positon the diverter is fitted?
