Yale 6400
26 Aug 2010
Denbighshire
Hi All :D
Finally got round to fitting the alarm. Little problem though - forgot to turn on the CU internal battery before wall mounting it. Obviously this needs to be on in case of mains failure, so can I unclip the CU from the mounting plate withoutthe siren going off? (even when alarm is OFF)If so, what is the best way? should I disable the siren :?: Also, is the entry delay dependant on the battery being activated as the alarm is instantaneous even on a sensor designated as entry. Also, chime doesn't work. Can it all be related?
Thanks, Kev
set tamper off first. i would also then unplug it from the charger.
The other points are not caused by the battery being switched off.
Is you entry sensor a door?
Yes it is John - the setup is protecting a link detached garage (theres nowt worth nickin' in the house!) so the side and main doors are both on DC's with a PIR protecting a rear annexe, which is out of sight of main room.
