Yelow water in CH
22 Feb 2008
Southampton
Hi
The water in my sealed CH system is coming out of the radiators yellow, a nice pi$$ colour!
I know it's not the inhibitor as I drained the system a couple of weeks ago when I took the PRV off to clean it and then filled it after obviously with fresh water.
The PRV clean didn't stop it dripping so I've bought a new one, before I fit the new PRV should I run some Sentinel X300 or X400 or Fernox F3 through the system for a few days?
Cheers
K
what inhibitor did you add when you refilled it?
If the answer is "none" then of course you are seeing the results of rust and corrosion in the system.
A week or so without inhibitor will not do much damage. Drain it out and refill with inhibitor soon though.
If the system has been running for years with no inhibitor, you could use one of the chemical sediment cleaners.
Vent the rads when hot (and pump not running) to remove all possible air or gas.
As the system had been leaking (through the PRV) and I'd been filling it up everytime to be honest it could well have been six months without any inhibitor as it all would have leaked out and then watered down in strength when I'd filled it up with fresh water each time.
Which one? X300 X400 or F3?
Cheers John
I normally use x400 which you can leave in for weeks if you want as it is not at all aggressive, but the pros prefer the faster ones like X800.
If you use X400 you can put it in today and leave it (up to 4 weeks) until you get round to changing the PRV and refilling with X100.
X300 is for new systems, not old corroded ones.
If you are in a hard water area then (on final fill) you can add X200 which removes limescale but is not flushed out.
http://www.sentinel-solutions.net/product/listing/central-heating/liquids/
They were out of stock of X400 so I got X800. How long should I leave it in the system, 1 day?
Can't really see anywhere on the Sentinal website that specifies how long
don't know, the website just says "until clean". Try phoning Sentinel. When powerflushed it is usually in and out in a single day.
