Hi guys,
This is a 'what would you do thread'.
My dilemma is I have two taps on the side of my bath which are 1-2mm from the wall behind them. The sealant behind them has gone mouldy and could do with replacing. I have used some grot buster (recommended on here) which has helped (pic below is before I used it), but it is still a bit of an eye sore. The taps are tight on the bath, with the nuts on the underside of the bath lip.
Now, my original idea was to try and move the bath out to give me more room to work with/re-seal whole bath but I fear it has been glued to the wall and pulling it out would damage the bath and/or tiles. Seeing as when it was all installed a year ago the guy did a really good job with the rest of the bath & room for a very good price, (all except behind these taps) I am hesitant to turn this into a bigger mess.
Now, I am considering removing as much sealant as I can then really piling it on so that it forms two ''hills'' at the base of the taps and a large curve between them, idea being to maximise surface area for run off, as opposed to the water pooling behind the taps.
What do people think? If not, any recommendations? Thanks in advance!
http://dl.dropbox.com/u/72120595/IMG_20120813_172727.jpg
