Afternoon all,
Apologies in advance about the essay.... thought as much info as possible would be useful.
I'm hoping somebody can help me out on a problem with our 6 year old Zanussi washing machine.
A few days ago we noticed that the drum would not turn at all under any wash program. The machine was filling and draining OK and would work its way through a program, but the drum wouldn't turn at all, and certainly wouldn't spin.
Turning the drum by hand was OK in both clockwise and anti-clockwise direction, no obvious obstructions or bearing damage. So checking other posts on this forum, it looked like the best thing to do was to check the belt and the brushes. The belt was OK, but the original brushes were quite badly worn. I've just managed to fit some new brushes this morning without too many problems.
The machine now fills and drains OK, and to my surprise the drum on the machine now rotates <hurray>, but doesn't get anything up to full speed <boo>. Also, the drain pump seems to be running permanently on the two spin cycles (600rpm and 1050rpm).....
Can anybody shed any light on where the problem is? Looking at other posts, it has been suggested that this is a problem with the timer mechanism....
If it is the timer that is also faulty, would this be fairly low cost to replace? I've just spent £24 on new brushes and don't want to spend too much on a replacement timer if the problem lies elsewhere....
Any advice would be very much appreciated!
Regards
cap3116
Regards
cap3116
