Zanussi hob very hot after testing!
...have I wired this correctly?
It does appear to be correctly wired.
Only comment i would make is
The black sheath of the cable should be clamped by the cable clamp
I have tested one cooking zone. Top left 145mm smaller one. Brought some water to the boil. No heat at all in the cable. But the hob itself is red hot on the steel in that zone. The rest of the steel is cool to touch. But even at the very edge of the zone I used it is untouchable. It's that hot.
As I said at the start, and particularly now that you have confirmed that the connections to the hob are correct, this really can't be due to your house's wiring or the connections. Without being there, we obviously can't judge what we think about how hot it is getting, but if you feel it's getting too hot, that only really leaves a fault (or, unlikely, a design fault) in the hob - so, as I said, I think you need to talk to the manufacturer or seller about this.
Kind Regards, John
But that's not the reason for the apparent overheating.
I didn't say it was.
It will be hot at the edge of the zone. The heating area has to be over 100°C to heat the water to boiling point so the are around the hob is going to be hot.
Some compact hobs have internal cooling fans fitted to reduce the heat in parts other than the actual heating area of the hobs
If it was an induction hob then the area around the hob can remain just warm while the contents of the pan are boiling, ( the area under the pans will be very hot )
I think their is a language problem and unrealistic expectations.
Of course it is. It will be.
