Zanussi ZWF14070w1 - Almost 2 yrs old, Moved the position of machine and ever since it has not worked.
It would not fill, so checked double valve and found one of the solenoids to open the valve did not work. Bought genuine part and replaced, tried machine again, it filled once but would not then continue cycle.
Drain and Spin still work OK (drum turns and souns like it draining), Tried machine again on any wash program and it doesn't do anything. Tested new valve and still OK. Doesn't seem to be getting a voltage signal to open to allow water in.
No lights flash on front indicating any faults. Filter is clear. Pressure switch doesn't seem blocked. No loose wires are obvious. Any suggestions?
