After an earlier problem with unsatisfactory mist coat adhesion, (as suggested by Mister Helpful, Joe-90, Phatboy and others) I am turning to Zinsser Gardz and have finally found a local supplier.
From what I can tell Gardz is basically a drywall/ plasterboard sealer (with better marketing). I will be using it as part of a remediation strategy on previously prepared surfaces (I'll update that post at another time) and also as a matter of course on the rest of my walls to ensure a good foundation for decoration (belt and braces for the paranoid DIY'er).
From those of you out there who have used the product in the real world, I would really appreciate any advice or tips you think might be worth passing on.
Here are some of the basic sort of questions that come to mind.
Application:
- Brush or roller? If roller, short or medium synthetic nap?
- I need to do the ceiling and then later the walls; and when doing the walls, I can't do all the walls at once. Is there any issue with ridges / or banding I should try to manage (and if so how)?
After first application:
- If orange peel / roller stipple too pronounced, lightly sand or not?
- My understanding is that if there is any more filling to do, the process should be fill, then touch over again with Gardz. Any pitfalls trying to fill a Gardz coated surface?
Painting over:
- I can't imagine why it would be different, but if I failed to ask the question then I would no doubt soon enough learn that there is something I needed to know.
All perhaps somewhat basic, I know. And I could probably stumble my way through with out too much going wrong (optimism is so important if you are trying to finish a house). But, If you have some advice to offer, I will be grateful if you might share.
Thanks!
Application:
Painting over:
Thanks!
