- Joined
- 11 Dec 2007
- Messages
- 425
- Reaction score
- 5
- Country
I've used BIN before. Bit (or rather a lot) of a P.I.T.A to work with but it did the job well when i used it. I painted the doorframes which we'd stripped back as best we could to wood, taking off 80 years & god knows how many layers of paint & some weird honey coloured glue like stuff.
Thing with these is - i painted the whole lot.
I've got a fair bit of skirting to paint up. If i can get away with spot treating the knots then i will.
Either way, on top of the Zinsser i'd be using Johnstones Water Based Primer/Undercoat & then Sikkens Satin Water Based paint. Rubbol BL Satura or whatever weird name it has.
My concern is that where i spot treat the knots it'll flash through the primer & top coat.
Has anyone used this & can comment on what i should expect (as far as flashing through goes) with this?
Also, the Bullseye 123 is a stain blocker, so why would you use one over the other?
