Hello,
I’m looking for some advice on sealing a new window opening against a rendered exterior. I put the question here rather than the window section as I think it pertains more to building than a window in particular.
The wall construction is lightweight concrete block, then blue polystyrene (about 1 ½ inch thick), then a rendered exterior on an aluminium lath (I think that’s the right word - kind of an aluminium netting). The flat was build around 1989.
Here are a couple of pictures:
The exterior rendering is hard white ‘plaster’ looking stuff. It’s waterproof. I haven’t broken through the rendered cladding yet as I want to get as much of the window frame finished, then order the window, then break through and finish just before the window arrives.
I plan to line the opening with something like Hardibacker (cement based backing board – what you use for tiled shower enclosures etc), but am unsure how to seal the edge where this meets the outside cladding.
On the existing windows, it looks as though the edge has been covered with an aluminium angle, which is embedded into the exterior rendering. The window frame appears to overlap this aluminium to give a waterproof exterior.
Re-rendering the exterior isn’t possible (or desirable
), so I am wondering if an aluminium angle is what I need, and if so, how to bond and seal this to the rendered exterior?
Any pointers or advice greatly appreciated.
I posted this question earlier on the eBuild forum, but have not had any replies.
Kind regards
Malcolm Macaulay[/img]
Kind regards
