Boiler: Potterton Neatheat 16/22 Programmer Potterton EP3000
The boiler is functioning correctly, however I noticed the pump runs continuously. I checked the motorised valves microswitches which are operating fine. Next I replaced the boiler thermostat (which has built in pump over run stat), but this did not solve the problem.
This to me suggested either the programmer or the pcb? I removed the programmer (its one of those that sits on a back plate so easy to do) and the pump still continues to run constantly.
So could this be the PCB? Its an 407676, which I don't mind changing but is there any way of probing this out with a meter to prove the problem? Or any components on the pcb that could possibly cause this issue? Since other than this, the boiler if functioning correctly.
I am regularly now turning off the boiler at the mains, since I want to make sure the pump does not burn out ... Do you think this is necessary or Iam i being overcautious?
Any help much appreciated...
