what spacer
17 Feb 2008
Berkshire
putting 31cm x 45cm wall tiles up, should i use the 2mm or 5mm spacers for this size tile. being used in bathroom
Its a matter of choice on your part,5mm generally for floors,as a rule the larger the tiles the larger the spacers.2mm would be too small IMO as they are quite large.
i use 2mm on nearly all wall tiles. looks better in my opinion as you dont see too much grout
just spaced them at 2mm, dont look right, i personally think 4-5mm is looking nicer with that size tile, i will think on it
Those are quite big tiles, make sure your walls are very flat, or you will have problems where every 4 tiles meet at the corners.
Are all the tiles exactly the same size, check them, as 2 m/m may not give you sufficient adjustment if you start to go out of line....
thats why i'm thinking 4mm/5mm just incase.
all walls apart from one are flat, the worst wall i will do first and start the top roe first allowing a bit extra cement to allow for the slight bow towards bottom of this one wall
I would use 3mm personally
But it depends on the look that you are trying to acheive. I suggest that you glue four tiles onto an offcut of board and try grouting them up to see how they look. It will be too late when they are all on the wall  8)
