I have an old oven switched via standard "cooker" isolator switch in the wall. This has a 6mm cable to a 30A mcb in the CU. 20 year old install when house was built. No spare ways on the CU which is on the other side of the house from the kitchen. I'm changing this to a 5 zone induction hob rated 7.29Kw at the same position. Then I'm adding a double oven rated 5.8Kw on other side of kitchen. Considering diversity, is it reasonable to run another 6mm from the live side of the existing isolator switch, terminate it with another isolator at the new oven position, upgrade the mcb to 40A and connect the new oven to the new isolator
