Why is there fungus on my new ply roof (pics included)?
21 Feb 2009
London
I have'nt finished my roof yet as I still have to put the insulation and plasterboard up but this morning I just noticed some fungus or mold or something. I am not sure what it is but it doesnt look good.
I am building a gym so I dont think this would be good if i breathe it in.
I can't get the builders to redo the top as it already as 2 layers of torch on felt. (see pic) But is there anything I can do to fix this such as paint or some treatment?
I dont think rain is getting in but could it be due to the parafin blow torch being on to heat the gym whilst working?
Cheers
Tony
for every pint off parafin you burn you get a pint off water into the air
just wipe the mould off with weak bleach solution
Will this come back? Are you sure its not damaged?
Also, I was thinking about getting parafin heaters when my gym is complete (as ive been told its cheaper than electric) but i am thinking this is a bad idea!!!
if you are going to use parafin
buy a dehumidifier as the damp will keep coming back
are you not putting a ceiling in?
I am going to put space blankets in and then plasterboard for the ceiling. If i clean the mold will this problem get worse if I dont treat or paint the shuttering ply first and just seal it in?
Cheers,
Tony
The mould is cause by moist air hitting the cold roof deck - condensation.
You will get condensation whatever heating you use
Remove the cold surface, and you remove the possibility of condensation forming on it and subsequent mould .
So if i insulalate and put up plaster board it should be warmer and so i shouldnt get condensation?
Also, should i clean the mold and paint it with something first to protect the shuttering ply?
wipe the mould off, insulate,fit a vapour control barrier and plasterboard over.
the mould will not return!.
Can anyone advise me if the above advise is still valid. My problem is getting worse and i feel if i just wipe it that it will still be there. See pics below of it getting worse.
Cheers,
Tony
Have you been using the parafin heater again?
the above points are all still valid........removing the cold surface removes the condensation!.
No,
I the parafin heater hasnt been used since but the door has been shut and there was condensation in there even after a whole week or so of not been in there.
So putting in insulation does this remove the cold surface?
courtesy of woody. :)
