wiring a switch correctly
  • Thread starter Thread starter greeny4
  • Start date Start date
Status
Not open for further replies.
G
greeny4
im trying to change a switch which has never been wired right since i moved in. The picture on the left is of the existing hallway switch upstairs which is correct. It is a two way connected to the downstairs hallway switch which is what im trying to change. Can you tell me which wires should go where on the switch on the right pic which is 2 gang, each gang has L at the top and L1 and L2 at the bottom. There are 4 cables, x2 red singles, x1 red and black and the yellow/blue/red which is from the the upstairs. Any help would be grateful as ive tried it a few ways but it still doesnt work properly cheers Rick.
from the upstairs switch, blue to com and red and yellow to L1 and L2.
This should then operate the upstairs switch ok then.
are you saying change the wires at the upstairs switch? this switch has never been touched, its the downstairs swith that is wrong cheers Rick.
Sorry no, I meant the cable from the upstairs switch needs altering downstairs. So downstairs you will have blue to Com and red and yellow to L1 and L2.
The other downstair switch is a mystery though - once you have done the above and it works, let us know what wires you have left to connect!
cheers thats the upstairs sorted, now for the other gang i have 2 cbles, x1 red single and x1 red and black. 1 is for the wall lights and the other i think will loop to the kitchen lights or switch. I have looked in the wall lights and they have a red and black cable in them thanks for your help so far cheers Rick
What do you mean by this? Do you have two cables AND 1 red and 1 black/red, or One cable containing red and black/red?
Please be clear.
Status
