Need help wiring a new digital thermostat
31 Dec 2010
Berkshire
I am replacing an old honeywell room thermostat with a programmable digital Drayton one but cant work out what wires go where.
below is a diagram of the current wiring - i have 3 cables in positions 1,2 & 4
The new stat has 3 connection points - C, ON & OFF - here is a link to the installation guide - http://www.draytoncontrols.co.uk/WorkArea/DownloadAsset.aspx?id=10384.
I thought it would be C = 1 (which should be live), ON = 3 (which is a switch i think) and OFF = 2 (which i think is neutral). However I tried this and the fuse blows?
Marc
Starting a new thread will not resolve your problem any quicker, on the contrary, helpers may get confused and not bother posting.
You are wrong in your thinking, about the wiring, C is the supply to the 'Stat, ON is supply back to boiler (combi) or valve (heat only blr),
Off would be to a MOMO valve, not usually reqd.
Why start another thread. :roll: unless you don't believe my last answer.
The brown goes to the C, and the earth goes to the ON and should have a red sleeve on it.
The blue neutral needs to be made safe with a connector block, and not connected to anything.
That's it two wires only required.
Use the brown and blue and terminate the earth wire. The earth should not be used as a live conductor.
That would mean altering it at source, e.g.boiler.
But I do agree it would be better.
The blue is a neutral, or am I still too drunk to follow this thread?
Just seen DOI's reply :oops: Better idea.
Better bu@@er off, :oops:
Mr. W.
ok thanks all. it doesnt work. perhaps the thermostat is broken...
you may have fried something if you powered it up with a "neutral", there would be a 'straight short killing something'
The OP is also running the same problem, twice, on another Forum. That means he has asked it four times in all.
Let him stew. :twisted:
