Hi all.
I am building an extension to my house and one of the major features will be the floor, I want to minimize the grout lines between tiles ( I would butt them if possible) and to have a perfectly flat floor.
The floor will be on 2 different areas the new extension will be 150mm slab then 150mm polystyrene insulation then 80mm screed with UFH then self levelling compound then travertine tile 11mm x 610mm x 610mm, in the existing house it will be on a wooden joisted floor so I will be placing battens then chipboard then insulation then screed with UFH then self levelling compound then tiles, I hope to have a seemless transition between the new and old sections.
Any advice on
A. getting minimal grout lines and whether thier is a minimun due to expansion or the grout getting in to the gap, would Epoxy resin for example be a good choice ?
B. wether this is something I cqan do with time and care, for example I was thinking if I could get some flat wire mesh approximatly 5mm thick and lay this on the floor then blot mastic on the back of the tiles and push them down until they sit on the wire it should make for a perfectly flat floor, or if the floor was perfectly flat maybe use some other sort of glue and lay them like carpet tiles ? are these stupid ideas ? should I stick with the more traditional approach I just dont want to be breaking up some tiles because they sit up slighly after the tiler has laid them as I dont feel confident to go with the tradional approach myself.
Feedback greatfully appeciated
Any advice on
