baxi 105e problems
10 Mar 2006
Durham
had this boiler fitted now for nearly 2 years no problems until recently.
firstly when i run hot water it seems really cloudy only way it stops if i open tap fully but then water is barely warm and even when only slightly opened it isnt as hot as it used to be
secondly i've have a bit of air locked in a radiator (bathroom) and no matter how much i bleed radiators it wont go away. i've also took that radiator off and flushed it out put it back on and it seemed to have gone but is back again.when i turn heating on a can hear a gurgling sound coming from that radiator yet if i turn valves off it doesn't happen
anybody help me please
ps also i've had all upstairs radiators off at same time while decorating will i need to refill inhibitor and is it easy and whats the best way to get it in system
The cloudiness is just dissolved air!
Totally harmless and results from suddenly allowing the water to run from the mains pressure into the atmosphere.
Tony
never used to be like this is there any way to get rid of it as im not getting water heated like i used to
