Almost got the parquet down (at long last) and now thinking about sanding. Due to the size of the area a large drum sander or something like will be too big. My plan is to hire an edging sander (orbital type) and do the whole floor on 80 grit to level it. My neighbour is a french polisher and has a large normal sander which I am then going to go over the whole floor 100 grit.
I am then going to get some Lecol wood filler 7500 I think it is then 120 grit it and hard wax oil.
Does this sound ok to you more experienced parquet people or will I have trouble with rings off the orbital ?
The floor is only 1 or 2mm out in some areas so not a major sanding session I hope !!!!
Many thanks
Paul
Many thanks
Paul
