Hi, found this forum through a google search. Hope I can get some help with a problem I'm chewing on.
I'm currently renovating my place & one of the things I would like to do is to add a shelf to the living room. The flat is fairly compact so to save floor space I plan to run a single shelf right across an entire wall of the living room. The span is over 4 meters so I'm not expecting to be able to have one length of shelf right across. The shelves would need to accommodate books & magazines so would have a heavy load & be around 300-250mm deep & there will be a cabinet running above the whole shelf. The wall the shelf will be running along is solid so I can bolt to that quiet happily but one side is a stud wall.
What my dilema is is that I would like to acheive this so as the support cannot be seen as much as possible. The solutions I've come up with & need to know if they are workable are:
To recess into the plaster & attach galvanised steel angle brackets which can be fitted under the shelves (like an upside down L) or above for the tangent to protrude under (like a rightway up L) with the underneath of the shelves reccessed to accommodate the flange of the bracket. The brackets I've looked into are 90mm long/60mm wide 2.5mm galvanised steel which I'd have 3 for each meter long shelf but possibly longer (deeper) brackets are needed.. not sure.
I'm not sure it can be done without some other support so one compromise I've thought of is to have suspension wire coming from the wall: the ceiling above is covered by wall cabinets which are going to be around 300-400mm above the shelf so the wire supports would be running at around a 45º angle when attached to the heighest possible point to the edge of the shelves. I'd prefer not to have to use this method as the whole point is to make the shelf seem part of the wall.
So do these solutions sound feasable or am I underestimating the problem?
