No, I think you need to ensure your bonding is up to scratch and the installation should also be inspected, tested and certified before being placed into service, basically the fundamental requirements of chapter 13.
So you don't think that working to parts 3, 4, 5 (& if applicable 7) of BS7671 means that you've made reasonable provision in the design and installation of your electrical installation in order to protect persons operating, maintaining or altering the installation from fire or injury?
OK.No, I think you need to ensure your bonding is up to scratch
But what about work done by people who are not able to inspect, test & certify?and the installation should also be inspected, tested and certified before being placed into service
Why not? What reasonable provision(s) are not covered?So you don't think that working to parts 3, 4, 5 (& if applicable 7) of BS7671 means that you've made reasonable provision in the design and installation of your electrical installation in order to protect persons operating, maintaining or altering the installation from fire or injury?
No.
That's not a problem with CORGI, or the regime, or the "style" of the regime - it's merely one aspect of the legislation.the problem with CORGI style regime is that I don't think it prohibits you from doing DIY gas...!!
It doesn't regulate, it merely grants, or denies, registration and renewal of registration, and does so according to the authority given to it by the HSE.it only regulates those that are doing it for commercial gain from what I've been told.
When why mention it?though quite how you'd get on selling your house and having to admit DIY gas I've no idea,,
The onus is upon you to explain your "No.".Firstly, define your resonable provisions and then define your measurement of them. (You have referred to BS7671 so we will consider this standard only).
You're wrong.If you are going to adopt a 'standard' in order to accomodate the above, then you adopt the standard. You don't cherry pick the parts of the standard that you wish to ignore for whatever reason.
You're right.Of course, you can cherry pick and come up with your own standard.
The onus would be on someone else to show that the provisions of the cherry-picked standard were not reasonable.But if you do, why should anyone else accept it?
BS7671 is also a made-up, hotch-potch standard.Why would someone assume a liability for such a made up, hotch-potch standard?
Or to achieve a safe result in any safe way of his/her own choosing.it is still the responsibility of the DIYer to set out the Design and to complete the Construction.
Why don't you ask the person doing the I&T?How is the Inspector and Tester to inspect and test without a Design to refer to?
You're right. Again! It could become a habit if you're not careful.Now, there is no requirement to comply with BS7671 (unless in the case of defining a Special Location )
I think we all know, really.Of course, LABC might accept your cherry picking of BS7671. Who knows?
Amazingly, I agree with that.It's a better bet to demonstrate compliance with BS7671 as a whole than to cross your fingers and hope your LABC will be weak on the matter.
[It doesn't regulate, it merely grants, or denies, registration and renewal of registration, and does so according to the authority given to it by the HSE.
Loosely, I agree, which is why I said that CORGI doesn't do that.To regulate an activity or process is to control it, usually by means of rules or laws.
Nope - it's a simple administrative role, carried out by a bunch of glorified clerks. CORGI has spun the role into something bigger in order to sustain its involvement, but in the end has failed in that attempt.So Corgi controls the process of registration and continued registration by means of the rules given to it by HSE...
Hmm. I wonder what you think CORGI does when someone who isn't registered does what registration would permit them to do....thereby regulating who can or can't do something as laid down by the HSE.
A simple question was asked, to which a simple answer of 'no' was given. The questioner then asked 'why' I replied no. I then answered. I'm very sorry that this confused you.The onus is upon you to explain your "No.".Firstly, define your resonable provisions and then define your measurement of them. (You have referred to BS7671 so we will consider this standard only).
Isn't the onus on you to prove I'm wrong ??You're wrong.If you are going to adopt a 'standard' in order to accomodate the above, then you adopt the standard. You don't cherry pick the parts of the standard that you wish to ignore for whatever reason.
Any fool can do that.You're right.Of course, you can cherry pick and come up with your own standard.
The onus is on you to convince the person who will assume liability that it is OK for them to assume liability. If you can't convince them, they won't accept liability and your work doesn't get passed. Argue it all day long if you want, but if you want someone else to pass your work, you need to convince them.The onus would be on someone else to show that the provisions of the cherry-picked standard were not reasonable.But if you do, why should anyone else accept it?
Your opinion of the British Standard is irrelevant and your declaring it serves no purpose in this discussion.BS7671 is also a made-up, hotch-potch standard.would someone assume a liability for such a made up, hotch-potch standard?
And the proof of the pudding is in the eating. If you are going to use 'any' safe way, then you need to specify it so it can be verified that it complies with the relevant Regulations you intend to comply with.Or to achieve a safe result in any safe way of his/her own choosing.it is still the responsibility of the DIYer to set out the Design and to complete the Construction.
It is up to the Designer to specify, not the Inspector. If you wish to adopt another standard, then you must specify the standard and the inspection and testing requirements required to comply with that standard. Furthermore, you must specify the Design so that the Inspector can verify that the design has been complied with and that it complies with the requirements of the standard.Why don't you ask the person doing the I&T?How is the Inspector and Tester to inspect and test without a Design to refer to?
The answer being no, which makes your above points either meaningless or deliberately obdurate.I think we all know, really.Of course, LABC might accept your cherry picking of BS7671. Who knows?
The HSE regulates; CORGI just fills in forms.
Let's not go down that tired old route of you pretending that you're sorry, and we both know that neither of us is confused.A simple question was asked, to which a simple answer of 'no' was given. The questioner then asked 'why' I replied no. I then answered. I'm very sorry that this confused you.
No.Isn't the onus on you to prove I'm wrong ?You're wrong.
You have a good point, but if you're right then there is no onus whatsoever to prove it to you, or anyone else on this topic.The onus is on you to convince the person who will assume liability that it is OK for them to assume liability. If you can't convince them, they won't accept liability and your work doesn't get passed. Argue it all day long if you want, but if you want someone else to pass your work, you need to convince them.The onus would be on someone else to show that the provisions of the cherry-picked standard were not reasonable.But if you do, why should anyone else accept it?
I didn't express an opinion, and I wasn't being derogatory, but perhaps this revealed that you were attempting to be.Your opinion of the British Standard is irrelevant and your declaring it serves no purpose in this discussion.
Gladly. This is hypothetical, of course, but if I were a DIYer doing my own electrics then I would comply with The Building Regulations, both generally and with all its specific parts, sections, paragraphs, and sub-paragraphs. The Building Regulations use the words "reasonable provisions" and "safety", so my "provisions" would be "reasonable", and I would ensure that "safety" was paramount.If you are going to use 'any' safe way, then you need to specify it so it can be verified that it complies with the relevant Regulations you intend to comply with.
In that case your question must have been rhetorical, so I retract my answer.It is up to the Designer to specify, not the Inspector.Why don't you ask the person doing the I&T?How is the Inspector and Tester to inspect and test without a Design to refer to?
"No" isn't a valid answer to the question "Who knows?".The answer being noI think we all know, really.Of course, LABC might accept your cherry picking of BS7671. Who knows?
I sincerely doubt it.Corgi regulates those activities or actions that the HSE require them to do under the terms of their contract.
I don't have any opinion of them personally - the fact is that they do a clerical job, and they don't do it very efficiently. And I mean that quite sincerely.Your opinion of the employees of Corgi or your opinion of the work activities they carry out are nothing more than your opinion - which you are entitled to have but which others will decide are of relevance or not.
Sincerely, please show me where I was being flippant.You originally said:The flippancy of your tone suggests that your remarks are rather meaningless.
It's "CORGI", not "Corgi", although not for long. And I don't have any reason for being disgruntled, since I have nothing to do with anything that CORGI does.Then you said:The flippancy of your tone towards Corgi suggests a degree of disgruntlement.
No, but you do need to prove it to whomever is the decision maker. Either you will convince them or you won't.You have a good point, but if you're right then there is no onus whatsoever to prove it to you, or anyone else on this topic.
Mostly irrelevant.It's a fact that the IEEE has no elected authority, and BS7671 is not a mandatory standard. The Wiring Regs evolved over the years, having been originally "made up", and continued to be "made up". They aren't debated in Parliament, and aren't legislatively ratified.
Meanwhile, back in the real world....Good luck with your approach. Good luck with convincing anyone who has to 'certify' or 'verify' your compliance with the Building Regs (and put their liability - job- on the line in return for your unspecified, unprovable 'reasonable provisions').Gladly. This is hypothetical, of course, but if I were a DIYer doing my own electrics then I would comply with The Building Regulations, both generally and with all its specific parts, sections, paragraphs, and sub-paragraphs. The Building Regulations use the words "reasonable provisions" and "safety", so my "provisions" would be "reasonable", and I would ensure that "safety" was paramount.If you are going to use 'any' safe way, then you need to specify it so it can be verified that it complies with the relevant Regulations you intend to comply with.
I will convince them. Be assured. Be very assured.Either you will convince them or you won't.
Hardly irrelevant, since you brought up the matter of standards being "made up".Mostly irrelevant.It's a fact that the IEEE has no elected authority, and BS7671 is not a mandatory standard. The Wiring Regs evolved over the years, having been originally "made up", and continued to be "made up". They aren't debated in Parliament, and aren't legislatively ratified.
I've never had any trouble with BCOs in the past, and never needed any luck, but thanks for your well wishes.Good luck with your approach. Good luck with convincing anyone who has to 'certify' or 'verify' your compliance with the Building Regs...
