- Joined
- 1 May 2018
- Messages
- 1,637
- Reaction score
- 485
- Country
am I missing something?Oh nutjobs standards are indeed very low!
Actually it was 50% down and 50% when completed. Needless to say I haven’t paid the latter.You paid and you have them in your house. Until they are taken away, you are stuck with them.
Excellent. Looks likely you will be getting 50% discount. This may or may not be great depending on how inflated the price was. This is the first time I seen chipboard doors.Actually it was 50% down and 50% when completed. Needless to say I haven’t paid the latter.
It only counts as a discount if it's something you want, as the work is shocking then anything other than full removal and a full refund would be acceptable, it's not apparent if Dutch will achieve that ( I suspect not unfortunately). Whilst I'm no joiner I would add that anyone who claims they can prepare a door off site should be met with some suspicion.Excellent. Looks likely you will be getting 50% discount.
Exactly. Especially into existing casings. That particular door has a 10mm lipping on sides and top, so there is only a little room for adjustment. It may well be that your existing casings need too much adjustment in which case this should have been discussed rather than ripping so much off the cores are exposed.Whilst I'm no joiner I would add that anyone who claims they can prepare a door off site should be met with some suspicion.
Yes lesson learned !It only counts as a discount if it's something you want, as the work is shocking then anything other than full removal and a full refund would be acceptable, it's not apparent if Dutch will achieve that ( I suspect not unfortunately). Whilst I'm no joiner I would add that anyone who claims they can prepare a door off site should be met with some suspicion.
The agreed price for 7 doors with furniture supplied and fitted was £1540Exactly. Especially into existing casings. That particular door has a 10mm lipping on sides and top, so there is only a little room for adjustment. It may well be that your existing casings need too much adjustment in which case this should have been discussed rather than ripping so much off the cores are exposed.
Dare I ask what they charged? we don't know whether it was a cowboy job with a stupidly cheap price, or whether the price is a rip-off too.
TBH that is a bit too cheap, especially if it includes VAT. The doors are retail £150ish ea which only allows £70 per door for furniture and fitting. With labour calculated at ~£300 day (which should be minimum for a decent tradesperson) the price you paid doesn't really leave enough time to do a top notch job.7 doors with furniture supplied and fitted was £1540
I can definitely see top notches at the corners. Maybe something like timabuild could make them square again.the price you paid doesn't really leave enough time to do a top notch job.
totally agree. As I said in #3 when you pay professionals you are entitled to a professional standard of work. I've fitted many doors (in fact I'm making a pair of french doors and side panels from scratch at this very moment), but I don't fit doors professionally - I can't do more than 2-3 standard doors a day fitted to the standard I like to see. - Maybe 4 if they were a shoe-in with no fettling.Not sure the price has much to do with it, ignoring what he might expect to have to pay for a top notch job there's still a world of difference between what might be considered acceptable for the price he was quoted and what's he ended up with. If they underquoted that's their hard cheese. This is equivelent to a poor DIY job at best.
